Micrologix 1000 & Panel View 300 Micro
Mar 2008
Scituate, MA
Just built a new panel with micrologix 1000 and PV300 micro in the old garage tonight. Tested out the programs by connecting a 1761-CBL-HM02 cable between the two. As always, found an error and had to reconnect up the DF1 cable to the Micrologix 1000.
My issues...the 1761-CBL-HM02 cable male connector will not release from the female Micrologix 1000 connector.
The new 1761-CBL-HM02 cable has what appears to be a latching plastic slider over the connector and I assume a feature to provide a positive locking connection of some sort.
Can't seem to get it to release. I don't want to damage the PLC considering it's shipping tomorrow. Before I apply a screw driver for leverage...and advice?
Completely not a problem I was expecting tonight. I have used this combo many times in the past but it's been a couple of years.
Thanks is advance for any response.
HMM? I have one in my hand right now. If I hold on to the cable with one hand and pull back on the plastic slider this releases the latch. Then pull plug out of the ML1000. Maybe your latch is not releasing? Push in before pulling out to help it release? (Does that sound kinky?)
Thanks for the response...
I initially did exactly as you suggested including pushing it in to help release. Think I will give up tonight and attempt to break it tomorrow morning. Thanks
hi to everybody. Some time ago, i bought a stock box with a lot spare part of al old factory. I found a micrologix 1000 PLC (10 IN, 6 OUT) and a...
3,570
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
144
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,261
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
989
Hello All I am trying to convert a ML1000 program for use in a ML1400. I didn't create the original program & documentation is non existent...
4,417
