Micrologix 1000 w/HSC and Flow Meter
zmanvortex
Apr 2002
Nebraska
216
I am setting up a compact and low cost machine that will dose between 15 and 60 ml of liquid depending on the setpoint the user inputs. I have set this up and ran it but my accuracy is 5-10 ml and I need an accuracy of 1-2 ml. Does anyone know where I can get an accurate 24VDC pulse output flowmeter with reasonable accuracy without a hefty pricetag. I also think my pump might be too powerful and is pumping too much too fast. I need to dispense 60 ml in 7 seconds or less. The liquid is not caustic and is petroleum based. I will not be back in until Monday morning so I will check the posts then. Have a good weekend.
My bet would be to look for a peristaltic pump , this alone can do the job. Once the tube is filled, it's feed is very accurate.
To add a watchdog function to it you could go for a turbine flowmeter in line with the pump.
The down side is the tube replacement. You need to replace it when it breacks.
I need help how to use hsc instruction in micrologix 1000
2,518
Dear all I want to configure 660 ppr encoder to micrologix 1000 I used HSC instruction as per help I turned on C5:0/UA bit on, but I am not...
2,431
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
143
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,261
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
989
