Micrologix 1000 HSC
ggchavhan
Nov 2006
pune
135
Dear all
I want to configure 660 ppr encoder to micrologix 1000 I used HSC instruction as per help I turned on C5:0/UA bit on, but I am not getting high speed pulses for measurment, It is scanning as per regular scan, i.e. PLC is missing some pulses during the same scan. Please guide me in this regard.
Thanks.
there is a specific routine for HSC the counter should be in that routine to do high speed function
I don't know which routine it is I don,t have RSL500
I need help how to use hsc instruction in micrologix 1000
2,518
I am setting up a compact and low cost machine that will dose between 15 and 60 ml of liquid depending on the setpoint the user inputs. I have set...
4,013
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
143
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,261
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
989
