MicroLogix 1000
TMcDaniel
May 2020
Florida
41
Ive got a Micrologix 1000 that im am trying to use as a bench tester but its current setup has a password protect on it and no one here knows that password. I tried the Hyper Terminal trick but could not get it to communicate. Does anyone know how i can either reset the password or just clear the memory from the controller?
If you can establish communications with it, you may be able to download a blank program to remove the password and clear the memory. If not, try a firmware flash.
Edit:
Sorry, its a 1000 so you can flash it. You have to enter 65257836 (MLCLRMEM typed out on a keypad of a telephone) as the password. You have to have RSlogix500 V 3.01.09.01 to 9.05.01 EXCEPT 6.00.00. No versions after 9 support it according to knowledgebase article QA1358
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
133
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,256
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
985
Hello All I am trying to convert a ML1000 program for use in a ML1400. I didn't create the original program & documentation is non existent...
4,412
Hey Folks, I have a customer with an older machine that is controlled with a MicroLogix 1000. The machine just quit working. The power light is...
22
10,567
