micrologix 1000
shkoko2000
May 2011
cairo
296
i have micrologix 1000 connected with generator when i enter the generator to service the inputs and fault leds on and off (flashing) what i can do?
Hi, I am not sure what could be causing this but, while the processor is online and faulted, go to the upper left tab where you can change to program/download/online/etc. It should be marked red, click on go to fault code, it might hint you.
I had once a 0187h error code, somehow, that file I was trayinf to put in the PLC had a error that caused this fault, I did a new one with the exact things and it worked.
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
160
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,272
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
994
Hello All I am trying to convert a ML1000 program for use in a ML1400. I didn't create the original program & documentation is non existent...
4,426
Hey Folks, I have a customer with an older machine that is controlled with a MicroLogix 1000. The machine just quit working. The power light is...
22
10,614
