Micrologix 1500: 1764-24BWA or 1764-28BXB?
Elcan
Apr 2008
NC
935
Hello all,
I'm designing a 24 VDC system using a Micrologix 1500.
There are 2 options for the base unit:
  • 1764-24BWA —Twelve 24V DC inputs and twelve relay outputs, 120V AC power.
  • 1764-28BXB —Sixteen 24V DC inputs and six DC FET plus six relay outputs, 24V DC power.
Any suggestions, pros and cons, etc.?
Thank you!
I'm a big fan of flexibility. The BXB gives you added inputs, some solid state outputs (which can drive external isolation relays if desired), and 24VDC operation.
The 24VDC operation is nice, as you can run it off of a 24VDC supply, two 12VDC batteries, or combine the two with a battery control module, and you have a simple, reliable, effective UPS system for your controls.
More and more, I'm moving away from 120VAC inverter type UPS systems, and over to pure 24VDC control with BCM's.
I let someone use my Micrologix 1500 1764-28BXB to practice on, They accidently put 120VAC on it. I would like to repair it if I can. I have taken...
2,506
Battery is bad. Broke + terminal removing battery. Does this unit have an EEPROM available for it? Currently we have to reload program every...
2,256
Good morning Everyone, I replaced a micrologix 1500 1764-lsp processor this morning and downloaded the program, but when I try to put the...
3,615
Hi there everybody, Im having problems with setting up an ST401 proface touchscreen to a micrologix 1500 series c LSP 1764 PLC. I have a PLC...
4,142
