MicroLogix 1500 - trim pots problem
zitam
Jul 2008
Pruszków
77
I've strange problem. I try to use trim pots in MicroLogix 1500 controller. I've found function file for TPI, but I can't use it.
I tried to use for seting timer preset and used MOV instruction, but it doesn't work, I see the value for TPI:0.POT0 but it doesn't move to destination.
Do you know what should I do to fix that problem?
Regards,
Matt
The Micrologix 1500 and maybe others have (2) 3/4 turn trim pots on the processor. My question is has anyone used them and what was the...
4,973
93
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
923
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,211
