MicroLogix Power Supply
zblum
Mar 2016
Ohio
38
Are there any advantages/disadvantages to using an AC or DC power-supplied MicroLogix controller? I am using 24V field device in and out, but I accidentally bought a PLC requiring a 120V input to power itself.
In my field, we use a lot of battery backup systems. I like the 24vdc powered version for that (combined with a PULS buffer module and a big SLA battery). We always have at least a few 24vdc sensors so it makes sense to use the 24vdc powered version of the Micrologix.
I don't think there are any significant disadvantages to using 120vac powered Micrologix unless you don't have 120v available.
I have one installation where the incoming power is sketchy and the 120vac (ML1400) model lost its marbles a couple of times...probably due to a brownout. The plant operator added a household grade UPS to "cure" it.
I am not sure if they're more sensitive to transients on the AC line, but that is anecdotal at best.
I sell a lot of both but seams since the arc flash NFPA several years back more and more are splitting the cabinets, 24 one side and up on the other... guessing so they can access the 24v side (PLC and I/O) without dressing up (just a WAG)
Personally I still use BWA when building but I think either way is fine
I can't find the rating for the Micrologix 1100 and 1400 BWA processors. I need to know how big the power supply is. This will power an HMI...
2,803
Hi guys, I'm neck deep in other projects so I don't have the time to do the full research at the moment. I have a machine running a micrologix...
2,734
I picked up a micrologix 1000 really cheap and it came with no cables. I can pickup one of the communication cable at a store nearby here. I...
7,928
Howdy Everyone, I am doing a project with micrologix 1400 1762-L32BWA, where we talk thru message bits one direction and talk thru the discrete...
419
I'm very new to PLCs and have just acquired a MicroLogix 1400 1766-L32BWA. I can see on the output terminal block two terminals (first two on the...
3,660
