Mitsubishi FX5U-32MR/ES and GOT2000 hmi GT2104-PMBD configuration.
Puntigamer
Jan 2020
Graz
Hello everyone!
I'm a student from Austria and Im learning how to program, connect and configure the mitsubishi electric PLC FX5U-32MR-ES and the HMI GT2104-PMBD in the following softwares: GX Works 3 and GT Designer 3. Im learning that for a country level competition.
So when it comes to programming I don't have any trouble. But when I get into configuration and connecting both devices, then I can't figure it out myself. And surprisingly I can't find any up-to-date tutorials or manuals on the internet.
I hope someone can help me solve this problem and if anyone is willing to further contact me and explain/teach me a bit more in how to work with the softwares and hardwares, I would highly appreciate it. Thank you in advance.
Best Regards.
Here is the manual for Got programming communication selection is quite straitforward it will depend on you chosen communications type i.e. if standard as supplied with hardware then either 485 or ethernet, in communications properties just select the controller speed etc. I suggest you leave them as standard usually first in list.
https://dl.mitsubishielectric.com/dl/fa/document/manual/got/sh081197eng/sh081197engad.pdf
Here is the FX 5 manual
https://dl.mitsubishielectric.com/dl/fa/document/manual/plcf/jy997d55701/jy997d55701g.pdf
Hello there is a way to do the polyfit on 3rd degree on this plc. for imput i have a munimum value of 5 X and 5 Y value for example Measured...
58
2,655
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
167
Hi, I have a Mitsubishi FX5U PLC where I cannot established communication via ethernet port of my computer. Search all videos and follow all the...
1,252
Hi everyone, I am having a hard time trying to get a connection between this two devices. I am already lost on what went wrong. Please help me~~~...
857
Is it possible to have FX5U plc using sinking inputs and an expansion module FX5-16ES with sourcing inputs? The plc has relay outputs so NPN/PNP...
992
