Mitsubishi Got 2000 question
c3ham
Feb 2019
Sxorland
Hi guys
Is it possible to use an output (Y) for a bit lamp in gt works 3, I can't get it to work no matter what I do but I am a beginner so that's not saying much any help would be greatly appreciated. I am trying to upgrade an old fx system with mac 50 hmi to an fx5 system with got 2000 hmi.
Thank you
Craig
Hi guys
Thank you
Craig
Yes, you can use Y for bit lamp there are something that you need to do.
1. Create project and config communication with FX5U (Maybe ethernet connection) and config PLC and HMI according to this manual below (built-in ethernet connection).
https://www.allied-automation.com/w...n-Manual-Mitsubishi-Product-For-GT-Works3.pdf
2. Create Bit Lamp object then select device to Y address to be shown.
Hello, I have a GOT 2000 that is dead and only have a GOT 1000 spare at the moment. I have converted projects up from 1000 to 2000 before, but...
791
Good day all We had a GOT1020 HMI installed but has failed recently. We then Bought a GOT2103-PMBD. I need to download our old software to this...
1,412
Good afternoon, Called in today to work on a pneumatic pick and place. It appears while burning a material head off injection barrel they...
2,615
Is there an output or something that is similar to a screen saver, but you can use in the plc to know when the user is actively using it...
502
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,310
