Mitsubishi GOT Communicater Error after reading and writing
toolguy101
Jun 2013
greeneville
Hello All
We are running into a series of problems when reading from GOT 15 series HMI's then writing back to the same GOT. After writing to GOT we are getting are getting a 402 communication error. The GOT will no longer communicate
with the PLC. A specific example is a GOT 1572-VNBD connected to an A series Mitsubishi PLC with standard RS232. We are using GT Designer3 version 1.45x programming software.
The problem has something to do with the OS version.
Any Help much appreciated.
Is there an output or something that is similar to a screen saver, but you can use in the plc to know when the user is actively using it...
506
Hello, I have a GOT 2000 that is dead and only have a GOT 1000 spare at the moment. I have converted projects up from 1000 to 2000 before, but...
794
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,313
I am trying to connect GOT-A953-tbd HMI with Nittoku NSC30. Actually, earlier GOT-A953-tbd HMI was used to communicate with Nittoku NC350 and it...
1,390
Good day all We had a GOT1020 HMI installed but has failed recently. We then Bought a GOT2103-PMBD. I need to download our old software to this...
1,418
