Mitsubishi GOT script function
Asaddoris
May 2018
Georgia
19
Hello everyone,
I am currently working on a project to print data matrix codes. This function was already working but I was asked to change the size and style of the DM code so that it also prints a text string on the label as well.
This has not worked out the way I was wanting and I can not seem to get the text to print.
I am using a Mitsubishi Q series PLC and a GOT 2000 which is running a script for the print function. My printer is a CAB Squix and is hooked up via Ethernet.
The variables that it pulls data from is on the GOT as a text input which are D7710, D7720, D7750
Like I said previously, this script and printer function was working fine before and if I load the original script, everything reverts back and no issues.
I have attached the original script and the new script to compare, as well as the old and new label format file (loaded into the printer)
I need to hide/display a lamp by using a script. It says there is a script error but I cannot figure out where the error is. Can some one please...
2,850
Is there an output or something that is similar to a screen saver, but you can use in the plc to know when the user is actively using it...
505
Hello, I have a GOT 2000 that is dead and only have a GOT 1000 spare at the moment. I have converted projects up from 1000 to 2000 before, but...
793
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,311
I am trying to connect GOT-A953-tbd HMI with Nittoku NSC30. Actually, earlier GOT-A953-tbd HMI was used to communicate with Nittoku NC350 and it...
1,390
