mitsubishi GX Developer
George Graziano
Jul 2004
NY
447
We uploaded a program from the PLC. This was on a rung
the ---| |--- Had an address
the ----{ } had an address
but the ---/--- didn't. Whatever this is was preventing the Output from being true. No labels because we uploaded the program. We used the Demo version of GX Developer.
George
I'm not familiar with Mitsubishi's but it looks to me like an Invert Power Flow (or NOT gate) that inverts the signal at that point. I would look into what is triggering the input of that line & see if it should be off.
It was actually something like this
both inputs were on (High lighted), but output wasn't
George
Thanks Goody. What causes it to change state. Also, what is the opposite? --| |-- with no address?
George
George... the oppositite of 1 is 0 and the opposite of 0 is 1 so a not gate is same for both states......
I guess what I am asking is:
The --| |-- was true, but the output wasn't on. What made the / change state so that the output was then on?
George
George.. The / simply reverses the state of the logic... so if logic before it is off logic immediately after it will be on...and logic before it is on, immediately after will be off.
If everything is 'true' or on before the /
Then in your case, the output will be false or off
Any other condition before the / and the output will be on.
I have never used the / it's far too confusing (as you have found)
There are far better and easier to understand ways of programming the condition you want.
{posted at almost same time as cjd}
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,194
Hi everyone, I'm working on a Mitsubishi Q series PLC whose code was developed in Mistubishi's GX IEC Developer v7.04. I looked online for GX IEC...
1,518
507
On our system, on the HMI we've got a page of setpoints. These are the values at which alarms are set (e.g. a high temperature alarm or a low...
1,252
On our PLC we've got a HMI where the operator can enter a target rotor speed in RPM. When target speed is enabled, M70 = TRUE. Then the operator...
19
2,852
