Mitsubishi Servo and Control Logix
Mike Carter
Aug 2003
Nashville Tennessee, USA
23
Is anyone using Mitsubishi Servo Motors with Mitsubishi Servo Drivers but controlling them the AB Control Logix? If so what would be your application and what method are you using to communicate to the drivers.
UBE Industries has designed an all electric injection molding machine using a toggle clamp to hold the tonnage. The intriguing part is the all electric injection unit that uses Mitsubishi Servo motors and ball screws to drive the screw forward during the injection cycle. The machines are completely controlled with all Mitsubishi components so the integration is much easier using native Mitsubishi protocols such as SSCNET or CCLINK.
As the Mitsubishi Servo is probably the finest on the market, (based on my history with them) I would want to stick with those to retro fit an existing hydraulic toggle machine with an electric injection unit. But the controls on my machine are Control Logix which I would prefer to stick with.
I know Logix has many embedded motion commands with after market module designed for this purpose, but converting those commands to communicate with Mitsubishi is the unknown.
Does anyone do this?
Thanks,
Mike
Hi everyone. I try to using FB MC_MoveAbsolute, but Fb was error [1103 A value out of the range is set as a commanded position or travel...
848
we have a pipe cutting machine that was out of use for a long time, so the battery for plc was gone. I replaced plc battery, but now both servo...
1,017
Hi I selected a Mitsubishi Servo drive MR-J4-100TM-PNT for profinet communication. The supplier I am getting from this particular drive doesn't...
1,414
I’m fairly new to PLC programming. This is our first machine that uses an FX5 PLC rather than an FX3, and therefore GX Works3 instead of GX...
1,258
We have an OLD Mitsubishi servo drive MR-H22KAN-S300. What does S300 Means, i didn't find any information about s300 on the internet. Any one can...
1,393
