ML 1500 IP Address Change
rebel02007
Jul 2014
Swain
I am trying to change the IP addresses on 4 ML 1500 PLC's and was wondering if anyone could instruct me as to how I would accomplish this.
The ML1500 does not have an Ethernet port.
Are you sure its a ML1500? The ML1100 and the ML1400 have Ethernet ports.
Do you have something connected to their serial port? If so, what? (catalog/model number please)
It is a ML 1500 LPR series C. There is an ethernet hub connected through the serial port of the PLC. There is a C-More HMI attached to the Hub. Am I trying to change the IP address to the wrong thing?
At this point, I think we need part numbers for the cables even if possible. The Ethernet "hub" must be some sort of serial to ethernet converter, so identify that for sure.
The Ethernet/Serial device is probably a 1761-NET-ENI, which has a serial configuration utility available from A-B's website.
http://www.ab.com/linked/programmablecontrol/plc/micrologix/downloads.html
There are a handful of other vendors of Ethernet/Serial devices that might be connected to the MicroLogix, like Digi and LanTronix and Moxa. Those might have a different configuration mechanism.
Sorry for the waste of time everyone. I was instructed to do something from the engineers above me that can't be done. They found the program you have to use to change the Address on the 1761-NET-ENI and downloaded it. Thanks again for the help though.
Hi, folks, how is going? There are two PanelView Plus 1500 over our production line and they work well. Today I edited the...
10,789
How to resolve this issue?? My tp1 and tp3 have both 04-04-04-04-04-04 mac address
25
5,228
How do I address the on-board I/O points on the MIcrologix 1500? We will use the BWA model which I think has 12 inputs and 12 outputs, but I...
2,563
Has anyone found a way to change the node address of Channel 1 via ladder logic or writing to a memeroy location configured as a DF1 half duplex...
2,267
SIR I AM USING AB 1500, BUT WHILE UPLOADING A FILE FROM PLC ONLY ADDRESS IS AVAILABLE TO ME,WHERE AS WHILE PROGRAMMING I HAVE GIVEN...
4,954
