ML1200 RSLinx Comms settings.
Honga
May 2010
Aus
316
G'day forum!
I'm running a 1762-L40BXB (MicroLogix 1200).
My issue today is that when I connect using my serial cable (Works on a 1000 and 1100) and try to configure the driver in RSLinx I get the notorious "Unable to verify settings" etc.
See http://www.plctalk.net/qanda/showthread.php?t=8941
I know that the issue is not the:
Computer
Cable
Port Settings
My MicroLogix 1200, unlike the one mentioned in the linked post, only has one serial port next to the trimpots.
I am getting a fault flashing, but no way to pull the code.
If any of you have found a resolution to this and could help me out that'd be much appreciated.
Fixed!
Was that I wasn't getting a good contact on the comms reset button.
Used a paperclip. TOo easy.
Hey all! Long time reader, first time poster! I have an EA9-T7CL and an MicroLogix 1200 connected via DF1. I'm all good and got everything mostly...
653
Hi every master,Recently i met a fault about 1762-L40BWA 1,When i get the PLC, The Fault light is lighting, I am not remember the fault message,I...
719
Hello everybody and master,I met a problem about ML1200.It is described as below: 1,When i got this PLC,The FAULT light is lighting, My computer...
1,111
I had planned to use PTO instructions to control a servo motor, single axis only. We have a ML1200 BWA model. According to the ML1200 manual...
3,491
I am using Modbus to read 36 registers from a ML1200. 2 of those registers are suppose to be L11 data and 2 of the registers are F8 data. Long...
1,392
