ML1400 High Speed Counter
junior
Jan 2006
Seattle
271
Is there a way to reduce the sensitivity of the high speed counter on the ML1400? I'm using it to count the number of injections an injector has performed. The injector driver signal is not the cleanest. The injector runs at 100Hz, but since the high speed counter is able to run at 100kHz, it picks up every little spike and counts 10x as many injections. I tried building low pass & high pass filters, but nothing seems to help. Is there any way to filter in the high speed counter setup?
In the I/O configuration for the MicroLogix embedded I/O you can use a simple digital filter. The default filter is 8 ms, I think, but when I'm setting up high speed counters I usually turn it down.
Thanks Ken, I'll try that. For some reason I thought that when u use the HSC function, the input runs at 100kHz.
Hello, For a year, I had high speed counters working flawlessly. Today, they were still working. Now all of a sudden, nothing. All other I/O...
50
15,913
I’m trying to figure out if you can use the high speed output on a micrologix1400 to simulate an engine crank sensor. The crank sensor on an...
3,410
Hello, Got some help wiring and setting up my flowmeters on these threads. Now, I must scale the inputs. I've done this many times with the SCP...
3,429
Hi Guru's I have been trying to set up my HSC interrupt (HSC:0/HPI)to trigger a counter in my ladder logic. I read the manual like 5 times and I...
4,353
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
493
