ML1400 High Speed Output
junior
Jan 2006
Seattle
271
I’m trying to figure out if you can use the high speed output on a micrologix1400 to simulate an engine crank sensor. The crank sensor on an engine will give 60 pulses/rev minus 2 pulses. This means that there will be 58 pulses generated, but they will be spaced apart as if 60 pulses were generated. I would have a desired RPM as an input and the high speed output would generated the pulses accordingly (ie. If I desire 600 rpm, the pulses will be generated at a frequency of 10 Hz, if I desire 6000 rpm, the pulses will be generated at 100 Hz)
I’ve looked through the manual at the PTO function and I think I could use this, but what I don’t know is how to eliminate the 2 pulses as on the engine crank signal. Any suggestions?
TIA
Jr.
I'm wondering if I would I be able to use STI to break up the pulses and then restart the high speed output generation? Can STI work on such a fast timing?
Hello, For a year, I had high speed counters working flawlessly. Today, they were still working. Now all of a sudden, nothing. All other I/O...
50
15,917
Is there a way to reduce the sensitivity of the high speed counter on the ML1400? I'm using it to count the number of injections an injector has...
4,664
Hello, Got some help wiring and setting up my flowmeters on these threads. Now, I must scale the inputs. I've done this many times with the SCP...
3,431
Hi Guru's I have been trying to set up my HSC interrupt (HSC:0/HPI)to trigger a counter in my ladder logic. I read the manual like 5 times and I...
4,356
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
495
