MM440 - braking problem...
mitar
Oct 2004
zagreb
28
My program is doing fine...
Motor move and stop fine, but I have one problem. When I stop motor in one position I want to "lock" it there, but I don't know how...
The problem is when it lift cargo it displace from original position.
I'm controling motor via PROFIBUS.
I look at P1215 (on MM) for motor holding brake and set up on 1, I set up parametar r0052 on C in P0731-P0733, but nothing...
Can somebody help me ?
So you have set for example P071 = 52.C ?
And you have physically connected the brake to the output (via a contactor !) ?
And tested the brake prior to running with the MM440 ?
First Jesper thank you for trying me help...
Yes, but today I will change the cable to view if it is OK...
If the brake is not electrically isolated from the motor terminals, it will see the back emf of the motor. this will cause the brake to remain on.(released)
with a VSD external braking system it is important to seperately exite the brake. -
- you do not realy have a choice.
Hi, The first motor of a productionline has to stop real fast. Ow, btw, it's a carpet factory. The Drive is controlled on profibus. I see...
4,665
We have a mm440 drive that is not starting remotely in automatic. We can control the locally when in hand mode with 0-10v potentiometer. When we...
1,376
Hi all, i m new to this forum. i recently had an assignment where the user wanted to copy parameters from Siemens Micromaster 440 using BOP. Help...
5,801
Hi, I'm using PPO1 to communicate with MM440. I only need to read and modify MM440 parameters, so i sucssesfully use PKW mechanism. I don't have...
1,306
Dear all, Could you please help me a bit? Please check the attached pictures. PIW582 is the signal from the MM440. Act. Filtered torque. In the...
1,492
