Modbus AB Micro850 with Schneider Altivar Drive
willings
Oct 2016
Greymouth
Hi all, I am trying to control and/or read values from Schneider Altivar12 VFDs. Via Modbus on a AB Micro850 PLC (using the Connected Components Workbench Software). There seems to be two ways to do this with the Micro850, either with messaging (using the msg_modbus instruction function block) or with the Modbus mapping feature. I have a list of the communication parameters (see attached fileView attachment ATV12_Communication_parameters_BBV51917_1.4IE05b.xls) But I haven't had any experience with Modbus and I am not having any success. There is not very much documentation about how to do this, If anyone can help me who has done this or knows how to do it I would appreciate it.
http://www2.schneider-electric.com/resources/sites/SCHNEIDER_ELECTRIC/content/live/FAQS/12000/FA12122/en_US/Altivar%2021%20Modbus%20manual.pdf
Here is the manual for Modbus RTU fort the Altivar12 VFD.
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/2080-um002_-en-e.pdf
Here is the manual for the Micro850.
You will be using the Micro850 (Master) to the Altivar12 VFD (Slave)
Take a look at Example 2, Micro800 (Master) to PowerFlex 4M Drive (Slave) in the above manual.
Here is a great overview of Modbus RTU.
https://www.youtube.com/watch?v=OvRD2UvrHjE
https://www.youtube.com/watch?v=8FYFai21JPA
This should help you out.
Regards,
Hello, This is my first exposure to CCW Micro8xx family. Someone will write to my existing micro850. Modbus TCP is turned on and I created a...
176
Hello. I want to use micro850 to read and write registers from 120 modbus tcp devices. I want to know if anyone that implemented such a solution...
482
Hi all IÂ’m working on a problem in which I have to read sensor data from a data acquisition module in the field that only communicates using...
1,732
Hello All, I am posting this in hopes of getting a little help as I am very new to Modbus. I need to control the speed of a compressor VFD with...
1,333
Hi, Iam Working in a project where Micro850 and Epson ROBOT is there, I need to read and write bits to and from ROBOT. Iam Using TCP/IP and...
1,263
