Modbus communication between Altus NOC and MVI46-MCM
Dec 2005
Jakarta
Hello all,
We are currently developing a multiphase metering system that will be based on a Micromotion Altus NOC and Allen-Bradley SLC-5/04 PLC. Altus NOC using for measure liquid density, liquid temperature and liquid flow while SLC-5/04 using to perform net oil calculation. Altus NOC and SLC-5/04 connected by modbus communication using Prosoft MVI46-MCM.
To get liquid density, liquid temperature and liquid flow we have to access floating point register 2XXXX as stated on Altus NOC Modbus addressing manual.
The problem is standard modbus just recognize 4XXXX as floating point register, floating register with adress 2XXXX not recognized. Example ladder, user manual and training material for MVI46-MCM from Prosoft only explain how to access 4XXXX floating point register.
How we can access 2XXXX floating point register from Altus NOC using MVI46-MCM ?
Any help will be highly appreciated, thanks in advance
Regards
Ikhtiander
Good day Programmers I have a RSTi-EP CPE100 Standalone Controller from Emerson as well as a STXMBE001 (MODBUS TCP/IP) as a Modbus communication...
663
Hey Guys, I am struggling to read data from a "JUMO" make controller using modbus RTU with MLX1400. The communication between the devices has...
18
5,118
Hi All, I am using an Accuenergy Data Acquisition Server (https://www.accuenergy.com/products/aculink-810-data-acquisition-gateway-server/) to...
2,707
we use M580 which have an Modbus RTU port correct if iam wrong now should i have to read input data from ab micrologix through read var block and...
1,873
To execute MODWR and MODRD instruction of Delta PLC, I need address of register in VLT 2800 but I cannot figure out. Can any body help me? I want...
7,100
