phinix Member P Join Date May 2006 Location l.a Posts 33 Jan 14, 2007 #1 hello experts , I am having a hard time communicating with a serial device, using a adam-4520 rs485 to rs232 converter ,by opc modbus server ,on my laptop Any information can help !!
BobB Lifetime Supporting Member Join Date Jun 2002 Location Sydney Posts 4,557 Jan 14, 2007 #2 I use the Adam 4520 all the time between PLCs and devices without any problems at all. Suggest you check your comms settings and make sure you have a 120 ohm terminating resistor at each end of the RS485 line. Also make sure you are using a standard RS232 serial cable from your computer to the 4520. You can check your communications using Modscan software from the computer to the device. It is easy to find by doing a web search for "Modscan".
phinix Member OP P Join Date May 2006 Location l.a Posts 33 Jan 31, 2007 #3 problem Solved Funny , But the Problem Was, The Laptop I Used Was On Battery , And when So The Com1 Is Disabled .
danw Lifetime Supporting Member Join Date Oct 2004 Location midwest, USA Posts 3,428 Jan 31, 2007 #4 Thanks for the update. What make and model of laptop? Which Operating system?
phinix Member OP P Join Date May 2006 Location l.a Posts 33 Feb 1, 2007 #5 it is a dell d520 , os is xp-pro-sp1
