modbus via adam-4520 converter
phinix
May 2006
l.a
33
hello experts ,
I am having a hard time communicating with a serial device, using a adam-4520 rs485 to rs232 converter ,by opc modbus server ,on my laptop
Any information can help !!
I use the Adam 4520 all the time between PLCs and devices without any problems at all.
Suggest you check your comms settings and make sure you have a 120 ohm terminating resistor at each end of the RS485 line.
Also make sure you are using a standard RS232 serial cable from your computer to the 4520.
You can check your communications using Modscan software from the computer to the device. It is easy to find by doing a web search for "Modscan".
problem Solved
Funny , But the Problem Was, The Laptop I Used Was On Battery , And when So The Com1 Is Disabled .
Currently I'm working in a project, and there is a problem, we need to show what is going on with the CR30 through an app developed in VB.NET, we...
619
Title summarizes the overview of the problem. I am trying to make AVEVA Edge 2020 and a Schneider TM241CE40R to talk to each other via Modbus...
18
2,199
Hello Guys, I have a packaging machine in the company that I work for that have 8 Omron VFDs (3G3MV ) that are controlled via Modbus with CJ1M...
689
Hi Guys, I'm searching for Modbus address register (mapping) for SCAME 27F (HS81) Fire and Gas Panel. I need to pull data from the panel to...
764
How can a timeout be handled in an RX3i communicating Modbus TCP over an ETM? I have a CRU320 (firmware 8.95) setup in dual redundant mode...
1,259
