Modicon M340 - PWM Output?
Feb 2014
BC
I have an application where I need to control a hydraulic pump control valve via PWM. I know the X80 I/O has a Pulse Train module, but couldn't find anything that will handle PWM. Has anyone done hydraulic control with an M340 before?
Application is turning a grinding mill via a hydraulic motor that is modulated via a vale and pressure feedfack on the pump.
Thanks.
there is no such module for M340. You will have to find a device that accepts a 4-20 mA signal and generates a PWM signal of frequency proportional to your PLC analog 4-20 mA output.
Here is one that can go up to 5 kHz: https://www.axiomatic.com/signal-converter/pwm-converter-4-20-ma-to-pwm/
Does the hydraulic motor/valve manufacturer not offer some kind of controller, amplifier, electronics, or interface module?
Hydraulic proportional valves have PWM amplifiers that you can buy from the manufacturer. They usually take +/- 10 volts and convert that to a PWM using 2 to 3 amps PWM. The PLC or motion controller cannot generate enough current to control the valve directly.
[email protected] first question should have been. "What is the best way to control a ( provide model number ) hydraulic pump to do...….. using a ( model number ) valve that controls the ( speed, pressure, swash plate angle, etc )
Chances are, what ever it is, it had been done before many times.
I read something that their bmx ehc200 counter card does have outputs that you can use for pwm
Hey all, I am having an issue concerning the Modicon System Responsible for the operation of our Generator System. (Particularly Dresser-Rand...
2,574
Hello, I'm having a hard time understanding how to get a Modicon M340 to pull a Modbus address from an ABB Totalflow via Ethernet. I set up a port...
1,161
Hello. New to Unity and had a couple quick questions. Can a Modicon M340 output to a small multiline LCD screen and not a full HMI?
968
Hi, I'm configuring the M340 controller with ATV320 inverters via Canopen. Everything was fine until today, when after starting the electrical...
1,339
I've got an M340 hitting an Ethernet to Serial converter one read at a time. Each read is enabled through a one-shot r_trig. I've got some extra...
1,604
