Modicon M340 Variable Addressing
Feb 2008
Walnuc Creek, CA
31
Hello,
Considering the M340 as a Modbus slave, and another device attempting to access internal memory of the M340 using the standard holding register format (4xxxx), is there a way to map the internal memory words (%MW) to the holding registers?
For example, if I want to provide %MW200 to the Modbus master when they reference address 40001, how do I do this?
Thanks in advance.
Hello,
Thanks in advance.
Assuming your master does not need an offset:
When looking at the PLC from a a master on Modbus register %MW200 would be Modbus address 40200 so 40001 is %MW1 so if you want %MW200 to be at 40001 you would need to use the MOV or other command to move the contents of %MW200 to %MW1
Hey all, I am having an issue concerning the Modicon System Responsible for the operation of our Generator System. (Particularly Dresser-Rand...
2,559
Hello, I'm having a hard time understanding how to get a Modicon M340 to pull a Modbus address from an ABB Totalflow via Ethernet. I set up a port...
1,154
Hello. New to Unity and had a couple quick questions. Can a Modicon M340 output to a small multiline LCD screen and not a full HMI?
967
Hi, I'm configuring the M340 controller with ATV320 inverters via Canopen. Everything was fine until today, when after starting the electrical...
1,336
I've got an M340 hitting an Ethernet to Serial converter one read at a time. Each read is enabled through a one-shot r_trig. I've got some extra...
1,596
