Modifying Identification and Maintenance info with TIA portal
AlfredoQuintero
Feb 2015
Yokohama
1,561
Hello Siemens experts.
Trying to figure out how to change the I&M data of a Profinet device with TIA Portal, and I can appreciate advice from the experts as so many times in the past. I have tried to change the I&M data in the TIA portal project, then building the program with no errors. But, when trying to download the modified program, which must be different because the I&M data has changed, the TIA portal says:
"The configuration will not be loaded, because the online status is up-to-date. The configuration will not be loaded to module <<PLC NAME>>, because the online status is up-to-date."
As a result the I&M data in the device does not change.
It seems the TIA does not regard the change to the I&M data as a change to the PLC program. If I try using the online diagnosis for this Profinet device, I can see the actual I&M info but cannot change it. Is it possible that TIA portal does not allow the modification of I&M data, or more likely, my TIA Portal skills are insufficient?
By the way I am able to change the I&M data using PRONETA software and the licensed version of Profinet Commander, but I need to know if it is possible to change the I&M with TIA Portal.
Thanks very much for your words of advice.
Maybe obvious but you are downloading the hardware confige and not only the software ?
I don:t have specific knowledge nor experience using I&M data but a quick search indicates that the data is exchanged using RDREC and WRREC instructions.
Hello kalabdel. I&M0, I&M1, IMM2 and I&M3 are indexes 0xAFF0, 0xAFF1, 0xAFF2 and 0xAFF3, respectively. So yes, it is possible to write a program with RDREC and WRREC instructions to change these values. But what I need to confirm is whether TIA Portal has the functionality to accomplish this without writing a program, like for instance PRONETA does. I was not able to figure out how to do this, so it may not be possible, reason why I am trying to get such confirmation from some forum member with deeper TIA portal expertise.
That's a good rule, but which manual? The got like a couple of hundred of them.
Glad you got it figured out.
Cheers
67
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
711
Hey all, I have been trying to update the transfer lists on a pair of redundant CPE330s that are currently out running in the field. According...
773
Scenario: 1. An employer has a machine that isn't up to code/standards: hydrogen gas torch systems without safety shutoff valves, industrial...
54
8,966
I am new to Siemens world and need some help. There is existing program and I need to modify Function Block, add some inputs. I am offline. I...
1,968
