Moeller ps4 big problem :)
Goody
Apr 2002
Huddersfield W Yorks UK
1,081
I have done a lot of searching of old threads on this site about Moeller plc's and it doesnt look too good for my problem.
Anyway - here's hoping there is someone with enough experience with these dreadful plc's
The problem: A machine has a PS4 201 plc controlling it. It has 7 extention blocks including analouge I/O.
The machine developed a problem so in someones wisdom - they pulled out the eeprom while it was running. Aparently, they thought it might reset the fault. It put the plc in HALT - or 'not ready' mode.
They told me they had a backup of the program so all I had to do was reload it back in. They had the programming software and lead (Sucosoft 40) so my job would be simple. :)
Simple my backside!
After several hours of struggling with this software and trying to load the backup back in I was at a dead end (the backup file they had was not of the file extention that this plc was looking for.)
I used the diagnostics and this is what it told me.
Ignore the battery warning - they had a spare plc that I swapped out with the same result as before - apart from the battery was dead on this one
It then transpired that they had done this very same thing before and the plc that I had swapped out had been removed from this machine before.
When I tried to load the project file into the plc I got a message something like this memory is not the right type or cannot be written to - niether would it let me format the memory card - same response.
I am of the opinion that the operating system is also corrupt but I could not find any onfo in help files
Please, does anyone have a clue where I go from here
Moeller PLC's
Contact Applied Automation, Wales, for Moeller PLC support.
Phone: +44 (0)1656 767370
Fax: +44 (0)1656 767378
Email: [email protected]
Applied Automation
Dragon House
Princes Way
Bridgend Industrial Estate
Bridgend, CF31 3AQ
Mid Glamorgan
United Kingdom
Thanks for that moggie. I am in contact with them.
It turns out (through Applied-automation) that it must have been the battery that was removed while powered down - šŸ™ƒ
And the plc is now empty.
It also transpires that the backup file I had is a compiled version but was written with the old DOS software S30 and I dont have the source code to convert it to S40
Applied Automation gave me a link to download S30 but I cannot install it on my computers - no DOS and no floppy drives.
Unless any of you know how to give me a dos enviroment on a XP computer.
Seems I am stuck for now.
Thanks for your help - I am sending the plc to applied automation. They will reload the image file and send it back.
I can recommend these people for service and price.
Hi group, We have a bit of an issue which I am sure you guys have heard before, I did look at the previous threads but could not see if there...
541
Hi, First i'm a beginner and not a very good in english so i will try my best to be clear ! I work on an used installation and me and my team has...
675
Hello! I have a friend who now lives on his boat in a different country and he has reached out to me for some help. I am familiar with the PS4...
1,664
Hello, I recently got my hands on a moeller ps4-341-mm1, I do not understand this plc it won't boot. In the manual on page 65 says "The Runā€ and...
1,303
Hello! I am somewhat familiar with the Moeller PS4 series. It was fun for it's day; however, I am seeing a series of LED lights I don't quite...
1,154
