Motion Control 1756-M02AE Vs Ultra 3000
sunniday
Sep 2007
jakarta
Hai all'
help me please ..;)
Now i setup CLX-5000 motion control project, I use hard wire connection 1756-M02AE with ultra 3000 for skriver machine use encoder feedback. I ever done CLX-5000 for Industrial process application, but Motion control for me it's new .
please anyone guide me to develop my project
BR
Sunniday
Well, the first most important thing is getting the motor and drive sized correctly for the application.
Have you done that?
Hai Gerry
Actually , CLX-5000 with 1756-M02AE it's for raplace existing GML system.
I already print configuration GML become text file . do you thing information from GML is enough for motor and drive size?
Are you also replacing the original motor and drive?
What are their model numbers?
It's generally insufficient to only consider the torque ratings of the motor.
Good Morning , We had to change out a L61 with a L71 processor and it seems like our motion control is not the same . Have any of you run...
1,847
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
274
How do I adjust motion control parameters using Logix Designer? Such as: motion axis stop I will make an adjustment like changing the...
323
Hey guys, On my system, i got prop valve controling cylinder on the left and right to adjust the center of a lumber before it get in a woodmill...
933
HI using a G120 sinamics i used the Profidrive in order to control the position in the picture i showed how my system is ,alos how i set the...
1,071
