Motion Control Error Logix 5000
pgroff9
Dec 2018
Wisconsin
I'm getting an error that I can't find the solution to.
Motion control MASR .err 12 .exerr 7
The .err 12 is message error but i can't find anything for the extended error to try and pin down the issue.
Thanks in advance
You've probably looked at this already -> But are you issuing overlapping instructions?
It will generate an ExError 7 if you have an MGSD triggering at the same time i believe...
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
274
How do I adjust motion control parameters using Logix Designer? Such as: motion axis stop I will make an adjustment like changing the...
323
Hey guys, On my system, i got prop valve controling cylinder on the left and right to adjust the center of a lumber before it get in a woodmill...
933
HI using a G120 sinamics i used the Profidrive in order to control the position in the picture i showed how my system is ,alos how i set the...
1,071
Hi, I have an application that currently utilizes SEW drives and programming that we are attempting to convert to Allen Bradley CompactLogix and...
1,147
