Motion Control
kdcui
Dec 2007
USA
386
I'm considering a move from the biotech industry (process control) to a job in the packaging industry. However I've not really worked with much high speed IO, servo drives, and motion control in general. Most everything I've been programming has used standard 4-20ma analog and discrete IO, and has been designed to be S88 aware/compliant (batch processing).
I have some learning to do and am wondering if anyone could point me in the direction of some material I could read up on, or perhaps share some advice / hints / tips?
IMHO, you can just forget all that S88 stuff.
Packaging is high speed, low drag, and low margin. Quite the difference from pharm.
But, there are a number of bottom feeders in the low axis count motion business. If I were you, I'd get familiar with all of them, 'cause and OEM will change suppliers for a 2% discount.
Just MHO
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
72
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
295
How do I adjust motion control parameters using Logix Designer? Such as: motion axis stop I will make an adjustment like changing the...
329
Hey guys, On my system, i got prop valve controling cylinder on the left and right to adjust the center of a lumber before it get in a woodmill...
954
HI using a G120 sinamics i used the Profidrive in order to control the position in the picture i showed how my system is ,alos how i set the...
1,082
