Move ASCII into string SLC500
Have not done this in a while, but I believe you have to do it a character at a time. Look up the spec for strings and make sure you set the length or delimiter correctly.
There is an easy way, if you can enter the strings before the program is running - type them in manually, as shown in the attached picture.
1st tried to dis play ST9:2 in a PV550.
the 550 validates but using an embedded variable in a text object the data does not display.
But I can display ASCII A10:10
Was trying create text entry with ST9 file but no go.
I figured the ST9 would easier to manage. I'm going to try and save text names for recipes.
C:\Junk\Screenshot - 10_15_2014 , 3_23_12 PM.png
Are your ST9 strings all text and not number values? If so, that is more difficult to convert. I think a program could be written to convert all-text Strings to ASCII A-type file characters (2 charcters per word), but I have not seen a program on this site that does that.
Hi' I have 8 input bytes containing an ASCII value, now I want to move the contents of the first byte into an double word on the first place...
3,318
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
84
So I'm pretty green when it comes to troubleshooting in the field so bear with me. We have a Danfoss valve that opens/closes from an analog output...
23
979
Hi. This is pretty basic but I'm struggling to find an efficient solution. I have a float value of let say 666.555 that I want to move / split...
225
hi, I got a plc S7-1200 with SEW movitrac **** and i need to program something ridiculous if my application reaches sensor 1 then my SEW has to...
195
