move some mm
Circiter
Oct 2023
Belgium
23
hi,
I got a plc S7-1200 with SEW movitrac **** and i need to program something ridiculous
if my application reaches sensor 1 then my SEW has to move x amount of mm's according to what the operator selects on the HMI.
if my application reaches sensor 1 again after the cycle, my sew has to move an x amount of mm's again.
after 5 cycles the SEW has to go back to its original start position.
anyone has an idea how to program this ****?
thanks
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
62
So I'm pretty green when it comes to troubleshooting in the field so bear with me. We have a Danfoss valve that opens/closes from an analog output...
23
962
Hi. This is pretty basic but I'm struggling to find an efficient solution. I have a float value of let say 666.555 that I want to move / split...
214
Afternoon, I have a DB in TIA Portal V16 that is optimised. I cannot change this. There is an array inside that block which consists of 3000...
1,154
Hello, I am working on an application that inserts a splined shaft into a 'gearbox'. The shaft is rotating slightly to allow engagement of the...
1,282
