Move bits between data types and locations
J2009
Dec 2016
South Carolina
23
I am reading 32 bits from a DCS system into a DINT tag. I need to move this data into 4 INT tags. 1st 8 bits to one tag, next 8 bits to another tag and so on.
When I try to COP DINT BREAK_DATA.0 to INT BREAK_DATA.1 I get an error because data types do not match.
Is there any way to do this?
INT = 16 bits; 4 INT = 4 x 16 = 64 bits
You probably need to move a DINT (32 bits) into two INTs (2 x 16).
If this is the case then you need to use two BTD (Bit Field Distribute) instructions where the Source will be the original DINT.
The first BTD will use the Source Bit '0', the Destination will be the first INT, the Destination Bit will be '0' and the Length will be '16'.
The second BTD will use the Source Bit '17', the Destination will be the second INT, the Destination Bit will be '0' and the Length will be '16'.
Hi I'm trying to move bits in to a word. I'm wanting to move %10.0 - %10.13 (Onboard Inputs) in to %MW1 I've tried moving one bit in to another...
1,441
Hi I'm trying to move bits in to a word. I'm wanting to move %10.0 - %10.13 (Onboard Inputs) in to %MW1 I've tried moving one bit in to...
3,399
Hey. I need some input on how to solve this task i am struggeling with. In the picture I attatched to this post, i tried to display what my task...
40
16,459
I am using Unity Pro XL 4.1 Is there an easy way to move a Boolean value to every bit of an Integer? There is a function for moving a boolean to...
5,814
Using Siemens Step 7, I and wanting to move 8 sequential bits into a Byte using the label instead if the direct address so that adding/removing...
38
17,843
