DesertDog
Using Siemens Step 7, I and wanting to move 8 sequential bits into a Byte using the label instead if the direct address so that adding/removing variables will not cause me to need to readdress everything. Is there any simple way to do this. The bits are defined in the STAT section of a function block and I want to simply move them into a Byte. I have done this many times with GE & Melsec but cant find a simple way with Step in it 7.
