Bratt
Bratt formerly known as Klaus.
If you have Step7 v5.2 you can set the adress priority. So if you rightclick the block folder and select object properties you can change the priority from "hardcoded" absolut adress to symbol programming. So Peter the problem isent really a problem just a matter of settings.
