Move time/date stamp into HMI
saultgeorge
Jul 2015
Detroit
535
Hi folks.
First time I've tried to do this. I am using rs5K V.28 and change, FTV ME V.8.0. I have a project that entails moving values into numerical displays in the HMI. I have cycle counts coming in, and when a tool is changed out after so many counts, maintenance pushes a reset button on the screen and it resets the counter, and moves the counts into a history display (6 historical values). I got that with no problem. How do I move a time/date value into a numerical display? I used the GSV and "WallClock", "LocalDateTime" attribute. My question is it ought to show up in logic, but how do I configure the numerical display? It seems there will be at least 15 or 16 places. I'm just wanting to save Month, day, year, and hours/minutes. This is so they can see how long it was since the last reset. Thanks folks. I hope to wrap this up tomorrow. 🤞🏻
you have build it using CONCAT.
See Attached. It's an exported routine. Import into a blank program and check it out. It converts time to a string not a number.
Hi, thanks for the response. I tried importing it into an existing program and I can't seem to do that. When I try to open it is says no controller exported with the file. I've haven't done much with files sent over this forum--I have little experience with zip/unzip. I was thinking perhaps what I want to do is covered in the Panel View user manual. My old boss always got mad at me and told me to RTFM.
it's a subroutine not a program. Create or use any test program you have and use import routine.
i am using RS logix 5000 programming software for compact logix..i want to send date(ex:23-may-2013) into one single TAG(integer type)..i am not...
1,725
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
62
So I'm pretty green when it comes to troubleshooting in the field so bear with me. We have a Danfoss valve that opens/closes from an analog output...
23
962
Hi. This is pretty basic but I'm struggling to find an efficient solution. I have a float value of let say 666.555 that I want to move / split...
214
hi, I got a plc S7-1200 with SEW movitrac **** and i need to program something ridiculous if my application reaches sensor 1 then my SEW has to...
189
