Moxa RTU
curlyandshemp
Jul 2005
Toronto
1,903
http://www.moxa.com/product/iologik-e2210.htm
Anyone ever use these? How sensitive are they to noise on power that feeds the unit?
Been asked to look at an install where the above RTU units lock up every now again. From what I can see, previous integrator is using same 24vDC power supply to power Moxa RTU unit and supply IO power to Asco Red Hat solenoids. I firmly believe the Moxa RTU is getting 'scrambled' with the noise dumped onto the 24VDC every time an Asco valve fires.
Hi All, I have set up a Moxa NPort serial server for an application. Unfortunately the environment requires NAT forwarding between 2 systems...
830
We've been using Allen-Bradley's 1783-NATR and find it is easy enough to work with. Unfortunately, it only allows 5 ports to be opened per IP...
785
Dear all When I am using Moxa Mgate 5105 convertor for converting Modbus TCP IP to Modbus serial RS 485 I am getting swapped word as LSB and MSB...
1,405
Hello. I'm considering using DIN rail mounted, managed Gigabit Ethernet switches from Moxa...
20
4,982
Hej Guys. Is anyone that has knowledge about setting up communication via ethernet from Keepware OPC server to MOXA NPORT? the keepserver keep...
2,019
