MS Access as an HMI Pgm
JasonG
Oct 2003
St Louis
59
Im in need of a really simple HMI application for a job I did a year ago. I have 4 optical turnstiles/gates in an office building that are used to control the flow of people coming and going. At present I have a console that has about 12 LEDs and a few buttons to change the mode of operation show alarms etc.
What the customer would like to do is have this info displayed on a PC in this lobby as well as in there command ctr. What I was thinking is a simple MS Access database with just a form with buttons to toggle binary info in the PLCs "Micrologi 1000" My question is how to get the PLC to talk with access?
This could be tough to do.
I am not familiar with your PLC, so have no specific knowledge.
On a larger PLC, you could purchase a 3rd-party "driver" for your brand PLC that reads the PLC memory registers through a serial port or Ethernet port.
The driver is installed and runs on the PC. Then you open an application like Excel (probably easier to work with than Access), and create a "Reference" to your PLC driver. This in turn allows you to fill spreadsheet cells with values read from the PLC.
The problem with this approach is that a small PLC probably does not have an available serial or Ethernet port.
A more indirect approach might work, if you have only a few data points: Purchase a discrete input card for the PC. Then hard-wire a few outputs from the PLC to the new inputs in the PC. The input card will have drivers with it, and may interface directly to Excel or some other application.
My surgestion would be to get RSLinx Single node(I think) that enables you to connect to a single node, using DDE I've done a few excel sheets that do this kind of thing and they work quite well.
If You've not done any DDE befor have a look at
MrExcel
Jezz :D
I'd recommend Excel as well; it seems to be the universal host for the "Poor Man's HMI".
Rockwell Software's knowledgebase has a bunch of articles about using RSLinx to connect Excel to controllers. The MicroLogix 1000 has a perfectly serviceable RS-232 DF1 protocol port.
Getting the data into one PC is easy. Getting it to another.... well, NetDDE can be a challenge. I don't know everything about that.
Can an HMI access the control logix plc tag's Description? It's relatively new that the PLC stores the PLC tags descriptors in it's own plc...
1,316
Can anyone share the hardware/software in integrating Radio-frequency identification (RFID) security on a plant floor's OEM machine HMI's? I...
2,979
Hi all, What is everybody using for getting access to remote machines PLC/HMI local network for snagging and debugging from their desk ? We...
21
9,874
Hi All, We are looking at installing remote access for a client so that we can log-in remotely and troubleshoot the PLC but also so that the...
2,624
Hey guys, I am currently trying to set up a CR3000 to be viewed from from any where in the world. I am able to view the HMI locally (across my...
2,171
