Msg error in micrologix 1400 modbus master
Justin92703
Sep 2013
Tx
I am getting the following error when my msg is enabled: "modbus exception code 02 returned: illegal data address" any idea on what might be causing this? image.jpg
In the channel setup in my modbus slave device I have 9 in the holding register setting with a node address of 20. I am moving all of my inputs/ output into n9:200 with a length of 6.
The target device got the request but is sending back "I don't have that address you asked for." Check the 'MB Data address'. Make sure that N9 in the target device is big enough. Add a few to the size just to be sure. Maybe at least to N9:220 or so.
Thanks Bernie. I will give that a try later this afternoon. I would also like to add that I am doing the same msg for another node running basically the same program. Everything is moved n9:200 length of 6. So it seems like I may have something wrong in my n9: file.
I am reading and writing between two ML1400 PLC's. Previous versions worked just fine. Now all of a sudden I am getting an ERR message for only a...
3,367
Dear all, I am testing MicroLogix 1100 to read from SLC. In SLC there are 10 tags (starting from N51:20) that I need to read in MicroLogix. So...
3,622
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
365
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
428
Hi, At the moment, If the user fails to provide a valid username/password, the image attached appears "Invalid password or user name. Logon has...
1,577
