Multi-Screen KVM
junior
Jan 2006
Seattle
271
I'm trying to find a multi-screen kvm extender. Can anyone recommend a setup?
What I'm looking for is to have one computer with a screen, keyboard & mouse. Then use the KVM system to display at 4 remote displays, keyboards & mice each approx 75' from the computer.
Can a system like this be put together?
Attached is a schematic of what the system would look like.
Jr.
Sounds like you'd be better off networking them if they aren't already, and using remote control software like RealVNC or TightVNC. (or many other remote desktop apps) That's the way I would rather do it unless I needed video or had some other need for perfect smooth motion. The main computer will be capable of perfectly smooth motion, but the remote ones won't.
Simple what you need is reverse kvm's + a switch
Black box do a range, even RS do them
I have two systems running, one with 2 pc's 3 screens & 3 lots of mice/keyboard, this system uses a manual switch to switch the local console to either pc & each one has a remote kb/monitor & mouse the other uses one pc & 4 remote monitors/keyboard/mouse this has a automatic switch so just a flick of the mouse or keyboard changes control to that terminal
also pc anywhere works quite well but you can only have one connection to a pc.
Hi All, Good Day y'all. I'd like to know how to setup multi monitor using Wonderware Intouch Standalone Project. We have 4 monitors in a rack...
1,185
Hello, I had a question about benchmarking the Rockwell FactoryTalk View SE software. I've installed in the neighborhood of 30 different...
285
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
136
Good Afternoon , I'm sure there are many Ishida Muti-Head Weigh Systems . We have a Ishida CCW-M-214W Multi-Head system . We are...
547
Hi Guys, I'm trying to integrate Pilz Ethernet IP Module to ControlLogix. I added Pilz module as a Generic Ethernet module and I'm able to...
514
