multiple logical sequences using fbd language
titoo
May 2014
paris
Dear all,
I would like to do several logical sequences to do implement in an auto mode using fbd for exemple :
1 move motor forward until stop sensor
2 wait 2 secondes
3 move cylinder up until up sensor
4 wait 5 secondes
5 move cylinder down until down sensor
6 move motor reverse until sensor home position
I am use to do this sequences using grafcet (SFC language in Unity) but i am not familiar with fbd. Does anyone have some experience with fbd and could help me ? I already started to do fbd for each movement (start motor and move cylinder) I would like to put them together to do an automatic sequence.
I hope this question haven t been posted before, if yes please send me the link.
grafcet in unity is rather simple:
make a step 0 without any action for now)(here the program starts.
below it make a transition it should be something like startbutton=true
below it comes step 1
the action will be something like output1:=true
the transition below it should be stopsensor=true
etc
Doing this sequences in grafcet is not too difficult but my boss want the programm do be only in fbd. Does anyone know a simple way to do the sequences above in fbd ?
thanks
see attached
Hope it makes sense, just used a very simple snippet of code to give you an idea how to start.
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
153
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
512
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
317
I'm trying to use DTM browser to make make modbus poll from RTAC. I'm able to get the points in first poll object. But not able to get anything in...
127
Hello, I encountered a problem with the kinetix 6500 drive, error code s22, loss of 3 phase voltage. After disassembling and replacing the thermal...
170
