1. Read book
2. Make a proposed design
3. Share proposed design here
4. You will get feedback on good bad points
OR
Submit $200 retainer and I will do your work for you.
WITHDRAWING MONEY DEMAND
OK now that you are starting to toddle and falling we have PROGRESS.
When I was attempting to learn PLC with a Siemens I hooked up the power, wrote a program, and tried it out. It did not work. Then I disconnected the only input I had and THEN got an output. This scared me so I put the Siemens away and decided to find a qualified instructor.
The moral to this story is if you are trying to learn at home be awful careful. Use SMALL incandescant lites for a load on the outputs.
So I went to school where the course concentrated on Allen Bradley. You can configure an input as either normally open or normally closed ie the contact has that slash thru it. I think this has you as confused as I was. Here is what I did to figure this all out. I will not use any program specific terminology so you do not get screwed up on names.
Take a normally open momentary switch (like those used on a 3 wire starter for the start switch).
Hook it to the FIRST input.
Configure it as a NO and have that operate output 1
ALSO
Configure it as a NC and have that operate output 2
Take a Normally Close (ie a motor start stop switch)
Hook to the second input
Configure it as a NO and have that operate output 3
ALSO
Configure it as a NC and have that operate output 4.
HOMEWORK ASSIGNMENT
Predict BEFORE you actually hook up any wires
1 what outputs 1 and 2 will do after energize PLC
2 what outputs 3 and 4 will do after energize PLC
3 predict what outputs 1 and 2 will do when you push the NO switch (first input).
4. predict what outputs 3 and 4 will do when you push the NC switch (second input).
Now hook the whole thing up and see if they work as you predict.
Dan Bentler
