Need Profibus Help
PSU84
Jun 2004
WE JUST SHIPPED TWO 45-65% COMPLETE
MACHINES TO CHINA. BOTH LINES HAVE
S7-414 PLC'S, IL-70 TOUCHPANEL
PC'S AND SIMOVERT MASTERDRIVES 6SE7035-1EKG0 200KW A.C. INVERTER
DRIVES.I HAD ENOUGH TIME TO POWER
UP THE PLC'S AND IL-70'S WHICH ARE OPERATIONAL AND COMMUNICATING
THROUGH PROFIBUS.MY PROBLEM IS I
NEVER SETUP DRIVES FOR PROFIBUS COMMUNICATIONS AND COMMANDS IN S7.
SINCE THE DRIVES WERE SHIPPED
DIRECTLY TO THE EXPORTER AND
WERE NEVER EVEN POWERED UP
I CAN NOT EVEN EXPERIMENT.
DOES ANYBODY KNOW WHERE I CAN GET OR DOWNLOAD A GOOD EXAMPLE ON SETTING UP
PROFIBUS COMMUNICATIONS WITH SIEMENS DRIVES? ALSO I WAS TOLD USING DRIVES ES
MAKES THIS PROCESS EASIER. RIGHT NOW I
ONLY HAVE DRIVE MONITOR TO PROGRAM THE
DRIVES. THANK YOU IN ADVANCE....
Maybe this attach can give you some hint .I don't think it's much difficult .First you need to configure your hardware ,than you can program in your step7 and you can can call SFC14 and SFC15 in your program .as for simovert drive ,you need CBP(communication board),and set some parameter.P918 is address ,it must be the same as the hardware setting in PLC. The others you can refer to simovert drive manual.
Hello, I have some basic questions to ask about Profibus. Tt will be a little long to explain all, but I prefer giving all details to help people...
2,728
Hiya, In the past I have worked with AB PLCs, Citect, DH+ but I have recently changed jobs and struggling with the changes. Sometimes dont know...
1,676
We have around 140 MOV connected on profibus-DP in a ring topology(typical distance is around 1.5 kms) . These MOV will be connected to Schneider...
3,856
I have a system using a S7-318DP. I have purchased a Diagnostic Repeater and placed in the network to try and gain insight to problems we have...
2,040
HI THERE IF I'M USING PROFIBUS NETWORK FOR SCADA AND IF I HAVE TO DECIDE BAUD RATE FOR COMMUNICATION. SO WHAT ARE THE POINT TO BE CONSIDERED...
5,084
