Profibus Modbus EGX IJBs...need help understand
quak12
Dec 2010
Hamilton
Hiya, In the past I have worked with AB PLCs, Citect, DH+ but I have recently changed jobs and struggling with the changes. Sometimes dont know where should I start. At this new job we are using all Schneider products....I am based in Melbourne if someone is willing to help I am happy to pay and I'll really appreciate it...I need some help understanding the following:
1/ Schneider architecture...or products...What are the different types of PLCs.. there is so much happening,,,ethernet, modbus, fibre optic...im lost :(
2/ Remote I/O
3/ IJBs
4/ EGX
5/ Modbus
6/ Profibus DP
7/ Profibus PA
Please guide to me where I can learn from...find reading material....and other bits n things...
Cheers :0
I'm not a Schneider guy, but here's my take on Modbus.
It's my impression that Schneider now owns the remnants of Modicon, who invented Modbus, and that they're the main source of Modbus Plus.
Modbus Plus differs from generic Modbus in that Modbus Plus is not limited to a single master, rather there is a token passing scheme so the mulitiple masters can rotate as to who's the current master. This is used for fast update rack to rack communications. Modbus Plus is a licensed technology.
Generic Modbus is an open protocol (not licensed). The standards are downloadable (see link above). Hence, there are tens of thousands of implementations of various degrees.
Generic Modbus RTU (over serial RS-485 typically) has one master only.
Generic Modbus/TCP is essentially Modbus RTU over ethernet, but since ethernet TCP/IP does hold and forward in its switches, Modbus/TCP can theoretically handle multiple masters.
Hi Everyone! I am feeling some troubles while dealing with Profibus and Modbus. Is there anyone who can help me out in following questions? 1...
2,509
hello I use S7-317 CPU in new project to control production line. I use two old DC motor drives...in old configuration they were controlled...
1,758
Iam working on link PLC S7-317 2PN/DP as master using profibus to two old slave speed drives which have only modbus (rs-485) after search I...
2,021
Hi, On a project, i have to assess the possibilities of communication directly from a Labview application on a computer. Profibus: you need a...
3,289
Hi all I want your advice for my problem : I have two PLC control systems , first is an old one and I use an Intouch Scada system to monitor and...
3,402
