Networking question
Not to mention that I have to put my plc's ip address in a strings.ini file in my hmi directory. Write a vb script in the hmi to read this on startup. Indirectly address all of my plc tags with [plc_ip]. Yes, my code is set up for DHCP, but don't take my work for granted. Not everyone is doing this.
All recent Rockwell stuff I worked with default to class C private IP. (192.168.0.0/24)
I think it's actually 192.168.1.XXX/24, for example the AB Armorstart and Armorblock have a integrated network switch in them, the default IP is 192.168.1.XXX, the XXX represents 3 small rotary switches on the device used to set the last octet of the IP address.
These devices also default to auto-negotiate speed and duplex, but our local I/O networks are all fixed at 100 Mbps FULL duplex. I also seem to remember if you leave the switches at .000, DHCP is enabled, simply setting these switches to anything other than .000 disables DHCP in the integrated switch.
^ those things sound cool. Do they support modbus tcp?
The same thing is available in AB "1734 Point I/O", from which ArmorPoint is built. "1734 Point I/O" modules are for mounting inside an enclosure, and it has the same Ethernet/IP switch module option (among other AB comms plus PROFIBUS... but I don't think they have a module for Modbus/TCP).
However with the rotary switches set for "000", you can also set ANY IP address within the RSLogix 5000 module configuration, or also BooTP.
ArmorStart is a pretty cool device in itself, including how they can be wired, with ArmorPoint.
So the quick and short of the situation is that I designed an axle press that was sent to one of my company's other facilities. That facility just...
19
4,335
Good day all. If I would like a PLC on one LAN to communicate with another PLC on another LAN, is that possible without using a router? For...
2,866
Hi Y'all, I know next to nothing about network communication. My question is I have a network that I use to access the line PLC's, but a lot of...
1,738
Hey guys, got a question, I have a Micrologix 1500 an Automation Direct C300 and my laptop. I would like to be able to plug in while running all...
1,681
We had a security audit for our bank 6 months ago. We are now doing a follow up audit. Since the first audit they added a wireless access points...
2,035
