New to PLC programming
crackerbuzz
Dec 2016
Blenheim
Hi all,
I am a process engineer specialising in wastewater treatment plants (design & build).
I have been involved in the PLC design structure and layout of process plants but have not been trained in programming myself as of yet. (I have always contracted the programming side out).
I am now looking to get involved in the PLC programming industry and am looking for some advice.
1: What is the best PLC hardware & software currently? (opinions)
2: Are drag & drop software programs available yet, or are they still based on coding language etc?
Sorry if this sounds a little too fresh!
http://accautomation.ca/programming/plc-basics/
http://accautomation.ca/five-steps-to-plc-program-development/
The above steps will give you a basic knowledge of what is involved in PLC program development. Understanding of your process is more important then the actual coding of the program.
The best PLC hardware and software? That is a loaded question. Different applications would be better suited to some manufacturers.
I would check out the Productivity 2000 series for a wastewater plant.
https://www.automationdirect.com/p2000/index
Hope this helps you out.
Regards,
Personally I would try and learn the manufacturer that is mostly installed in your plant already.
No point learning Siemens if your plant is AB etc.
A second hand unit in the office connected to some switches and lamps will cost a few hundred £ / $ from Ebay. Sadly the software is going to be the biggest outlay, if its from one of the big 2.
There is a massive amount of info on You Tube of how to get started. I personally found sitting down with Google and the manual a great challenge and lots of fun learning as you go, but horses for courses, you may wish to go the classroom route.
Most of my piers learnt as they went.
Thanks for the replies guys... No I am looking at doing this as a career, so multiple process and plants may be programmed, therefore I guess I would need to learn multiple platforms?
Here in NZ you're most likely to encounter AB/Rockwell across the major industries. Get proficient with their products and you will be employable.
If your looking to stay in that industry than you may want to read Tom's book
http://www.plctalk.net/qanda/showthread.php?t=83233
I think he uses a lot of Automation Direct and not sure if you can get them in NZ but just about any PLC will work as they all do the samething, I think I would look at Siemens TIA
If you can, Learn the basics of all the IEC 61131-3 languages(Or at least Ladder, Function Block, and Structured Text).
That will serve you well with ANY of the PLC brands out there.
To avoid calls from frustrated plant maintenance staff at 3 in the morning, I would recommend staying away from structured text.
Poor advice. It is prudent to learn the main 3 programming styles. Because each has their own benefits and own situational use.
Unless its in the customers spec, you write in whatever way suits you and you feel more comfortable with and one that gets the job done.
What the Maintenance guy can beothered to learn or not learn, is of no concern to you.
So I take it you dont get the phone calls in the middle of the night, I would learn them all but for the most part write in ladder... and its not just so you dont get the phone calls but you also want your customer to be happy with your product, if their people can not fix/troubleshoot it and they have to call you every time then you did a disservice not a service for them
Write your programs so they read like book. Make it easy for others to follow the logic and the sequence.
A well written program is also a well documented one.
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
238
Hello colleagues, Some time ago I started my adventure with programming. With your help and the courses, things are starting to come together...
713
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
169
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
179
Hi, Does anyone have thoughts or know of, can point in the right direction any published materials with a plumbing centric point of you explaining...
181
