No startup logo on GOT2000
aceventuraCZ
Mar 2022
Hull
I started work on HMI Got 2000. In GT3 designer I created main screen, basic buttons and also set up startup logo.
All this was successfully uploaded on HMI and works fine. For some reason I made some adjustments on main screen and now startup logo disappear.
If I compare files I can see all PC/HMI. Anyone got idea how to get HMI working back again please ?
Thank you
Roman
There is "Specify Startup Logo" check box in upper left corner. If you click on it and you do not select image, logo will be blank. If you uncheck the box, logo will be default Mitsubishi logo.
I did this. Still nothing.
Only what I see, is booting (top left corner) and than main screen come up.
Upload application and I will look at it.
thank you SIR!!!
also, I created just test screen to try if I didn`t mess up setting while I was creating this project and is same. Screen is blank until main screen loads up.
I am sorry to be pain, I am newbie to this.
Take care
Roman
I have just run the application in the simulator & it shows the splash screen at start up, cannot see a problem with it apart from when I loaded it there was a message some parts parts i.e. folders in the workspace are missing do you want to force it open I selected yes & it opened the splash screen shows up as expected. perhaps there is something wrong in your installation of GTDesigner, I'm using GT Designer 3 v. 1.23.
I am using same version of GTD. I reinstall it as well. Strange thing is that original logo not showing neither. after turning HMI on it only say booting... in left top corner and thats it.
Hello all, In my facility we have multiple 3HP 460V motors that are being controlled by VFDs which drive conveyor belts. The drives are randomly...
221
Hi, I recently installed 2 1783-NATR devices into two of our machines. The machines are pretty much identical, both having 1769- L24ER-QFC1B...
304
Hey I'm setting up a powerflex 755T, but in the connected components wizard during startup, I'm getting an issue where next to the start button it...
236
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
634
First time poster and somewhat new to PLC programming. I own a brewery, have a programming background, and one of the machines on my canning line...
974
