Startup Wizard for Powerflex 755T giving issues
Mandel314159
Jan 2024
Arkansas
30
Hey I'm setting up a powerflex 755T, but in the connected components wizard during startup, I'm getting an issue where next to the start button it says "P603 Start Inhibits", this led us to page 25 on https://literature.rockwellautomation.com/idc/groups/literature/documents/um/750-um004_-en-p.pdf
"f STO is performed, the Start Inhibits parameter indicates the IGBTs are inhibited, and the HIM
indicates that the drive is not enabled. The Start Inhibits parameter is parameter 933 in
PowerFlex® 755 drives and parameter 603 in PowerFlex 755T drive products."
and while looking through that information, we also found page 77 on: https://literature.rockwellautomation.com/idc/groups/literature/documents/pm/750-pm101_-en-p.pdf
Our STS light is flashing yellow, as far as I know (which isn't much) there's no faults or alarms running, but the STS light flashing allegedly means that there is an alarm running according to:
https://www.manualslib.com/manual/1351153/Allen-Bradley-Powerflex-755t.html?page=79
I'm lost guys 🙃
Are you using the safety inputs for the STO function, or is the jumper still installed. One or the other needs to be in use or start will be "inhibited".
I keep getting this error when getting to the "direction test" portion of the startup wizard. It says "received an error response to a control...
2,771
It's been a while since I've done a Powerflex w/o a hardwired enable (enabling over Ethernet/IP). So I'm struggling with how you are run the...
1,396
Hello all, In my facility we have multiple 3HP 460V motors that are being controlled by VFDs which drive conveyor belts. The drives are randomly...
207
Hi, I recently installed 2 1783-NATR devices into two of our machines. The machines are pretty much identical, both having 1769- L24ER-QFC1B...
300
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
628
