Noobie PV 1500 firmware questions. Gurus Welcomed!!
gr8benwa
Mar 2012
indiana
57
Scope:
1:Modify logic to allow automation of 4 new grain bins to existing grain leg system automated by 1769-l32e/a compactlogix controller v16.
2: Modify Panelview 1500 hmi "GRAIN.MER" display "BinSelect" by adding 4 push buttons to screen which allow operator the ability to select the new grain bins.
Ok I already have what I thought would be the hard part done, integrating the 4 new bins into the logic. (motors, gates, conveyors, contact switches, and so on.)
What I thought would be the easy part was adding 4 buttons to a HMI screen! LOL!
Here is the skinny.
The original .mer was created with rsview 4.0 (or 4.1?) and I have rsview 5.1.
I loaded the (4.?) .mer into my 5.1 and added the push buttons.
ok so far so good.
Now I obviously need to update the pv1500 firmware to 5.1
Questions:
1- are there any problems that you may be aware of that I should be concerned about with what I have done and am about to do? (converting .mer file to 5.1 and then also plan to update firmware to 5.1 on hmi)
2- I see that I can do the FW update using my RSview studio 5.1 but have 2 questions.
2A: I see 2 options for selecting the device -panelview 1500 and panelview 1500 CE. I do not know which to pick. How do I know if the panel is a CE version or not?
2B: Once the correct device is selected, I see the browse button to access the FW update file. My Firmware folder is empty. I was hoping that RSview studio would have the file in the folder or a way to generate one. How and where can I get this FW update?
***BONUS QUESTION***
I do not have access to Rockwells database because I am using RsView ME studio v5.1 trial software on my 32bit workstation.
Am I screwed? :confused:
Thanks!!!!!!
dang no replies yet. I was suppose to have this project done today o_O
gave the customer a thumbs up yesterday after I tested the new logic using branched 120v digital inputs and everything worked fine. didnt expect the 4 push buttons on the HMI to set me back.
when I explained the problem to customer, they were not so happy and frowned on messing with the firmware of the HMI as a work around. UGHHH! I wish I knew someone who could just add 4 push buttons on one screen using the rsview studio that doesnt need a fw update then I could download it early monday morning and make the customer happy.
You need a support contract or a recent software purchase to be eligible for a firmware upgrade.
Fortunately, FactoryTalk View Studio ME can create runtime files for older firmware terminals.
When you create the *.MER file, select version 4.10 and the file can be loaded and run on your existing terminal.
holy cow I didnt know it could create older runtime versions!!! I never thought to see what would happen if I used the "save as" file drop down !! thank you!!!!!!!
We have a 525 vfd that works without a PLC and just with field inputs. The speed reference is set with the help of embedded pot. Is it possible to...
1,479
Hello everyone I am new to Siemens Step 7 and having some issues I was going to add the a FC to OB1 (Network 28 In Image 1) But it was asking...
2,398
Greetings, I own and operate a small textile mill and suffer from the constant desire to improve things. The machines we use are made partially...
1,722
hello all brand new to this forum and also new to PLC programming. here's my dilemma, I am installing a PLC and a VFD Drive unit into a conveyor...
114
21,031
Hi, I have been given task to solve operation of a machine controlled by an Allen Bradley SLC 5/01. Machine has been operated " out of sequence"...
1,975
