"Not Compatible" when going online to S7-1200 V3 Firmware
Andy6
Apr 2011
In the garage.
140
I seem to be having some trouble getting online to a new S7-1200 PLC. It has the new version 3 firmware. I have upgraded Step7 to SP2 Update 4, as well I installed the appropriate Hardware Service Pack for this PLC.
When I try to go online, it will not connect and will give me error "Not Compatible"
The fault light is blinking.
The model number that Ive selected and the model number on the PLC are an exact match.
Any tips?
Had the same problem with V11 basic, siemens delivered 9 S7-1200s with the new V3 firmware. Connecting to the 1200 went much better after upgrading the firmware to V03.00.02 using a memory card.
firmware is available here
Step7 or tia portal? there is a big difference between the two.
Yes it is TIA portal. But it still says Step 7 V11 on my DVD case.
firmware is available here .
Tried out the new firmware, works finally! Thanks!
I'm not actually in front of the equipment yet, but this is the information that I have been given by a client: ------------ Data from HART...
344
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,235
Hello, has anyone ever been caught in this situation? You have redundant CPUs, fieldbus is PROFINET, there are some devices which don't have the...
520
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,513
I am trying to load a .mer via USB to a PV+, when doing so I received an error that its not compatible. Using Dustin's little gem (thank you!)...
1,463
